roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
mnc042
Oct 15, 2009Aspirant
Skywalker wrote:
mnc042 wrote: Could the bad packet errors be something wrong with the NAS itself? Perhaps the network interface going bad?
I doubt it, since you would usually see the ReadyNAS sending out bad packets and not even knowing about it. In this case it's receiving them. I've personally seen a bad switch cause that before at my house.
Good enough. I'll give it a try and update here!
\marc
- Oct 20, 2020Retired_Member
