roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
mnc042
Oct 26, 2009Aspirant
Just an update on my side, I disabled guest access and I haven't had the failure in a few days, but I have gone days in the past without seeing the error, only to have it re-appear daily with a vengeance, so I'm not sure I'd necessarily say my problem is solved..
Just wanted to check in..
\marc
\marc
- Oct 20, 2020Retired_Member
