roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
rezonat0r
Nov 01, 2009Aspirant
Just had the error again. Hadn't had it in several weeks (since clean installing Snow Leopard, really). Wasn't doing anything unusual. Safari, Firefox, Adium, Apache2 are the only apps running.
System: Macbook (Late 2008 Unibody), OS X 10.6.1
Network topology: NAS to Airport Extreme (Dual Band) via CAT6; Macbook to AE via 802.11n (5Ghz)
TCP Retransmits: 811
Unrecovered TCP Retransmits: 38
(This is after the NAS has been up for several weeks and done many TM backups; don't have numbers from before the error unfortunately)
Shares: AFP only (no CIFS). Guest access on AFP enabled. Pretty much all other services are OFF.
Logs sent.
Logs sent.
- Oct 20, 2020Retired_Member
