roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
BoarderBlue
Nov 04, 2009Aspirant
rezonat0r wrote: Just had the error again. Hadn't had it in several weeks (since clean installing Snow Leopard, really). Wasn't doing anything unusual. Safari, Firefox, Adium, Apache2 are the only apps running.
System: Macbook (Late 2008 Unibody), OS X 10.6.1
Network topology: NAS to Airport Extreme (Dual Band) via CAT6; Macbook to AE via 802.11n (5Ghz)
TCP Retransmits: 811
Unrecovered TCP Retransmits: 38
(This is after the NAS has been up for several weeks and done many TM backups; don't have numbers from before the error unfortunately)
Shares: AFP only (no CIFS). Guest access on AFP enabled. Pretty much all other services are OFF.
Logs sent.
Hi there
I have been having the same problem (since I upgraded to a dual band AE) - TM fails with an error message "The backup was not performed because an error occurred while copying files to the backup disk" I haven't been able to complete a back up since a day after I installed the new AE.
Thanks in advance for any help or advice.
- Oct 20, 2020Retired_Member
