roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
mdgm-ntgr
Feb 15, 2010NETGEAR Employee Retired
rezonat0r wrote: Is it possible the periodic failures are related to this?
viewtopic.php?f=17&t=37714
Yes, I guess it is quite possible.
Netatalk is what is used to give AFP functionality on the ReadyNas. Snow Leopard made some changes that affected backwards compatibility with devices using older versions of AFP. The latest Netatalk brings improved AFP compatibility (I think), so it should work much better.
- Oct 20, 2020Retired_Member
