roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
mdgm-ntgr
Feb 15, 2010NETGEAR Employee Retired
I'm not sure if it does bring the newer AFP as I didn't see that mentioned anywhere (so I edited my post above), so it could still be AFP 3.1, but working better actually.
Here's some info I found on the netatalk version using RAIDiator 4.1.6
Edit: it is still 3.1. I was wrong before. The next version of netatalk (currently in public beta) should bring 3.2. See http://netatalk.sourceforge.net/2.1/ReleaseNotes.html.
So 2.0.5 should be some improvement and later versions of netatalk will be even better. It's just a matter of waiting for the newer version to become stable and NetGear to test the newer version of netatalk to make sure it works properly with the ReadyNas.
MDGM-NAS:~# afpd -V
afpd 2.0.3+cjk3 - Apple Filing Protocol (AFP) daemon of Netatalk
This program is free software; you can redistribute it and/or modify it under
the terms of the GNU General Public License as published by the Free Software
Foundation; either version 2 of the License, or (at your option) any later
version. Please see the file COPYING for further information and details.
afpd has been compiled with support for these features:
AFP3.1 support: Yes
Transport layers: TCP/IP DDP
CNID backends: cdb dbd
SLP support: No
TCP wrappers support: No
Quota support: Yes
Admin group support: Yes
Valid shell checks: Yes
cracklib support: Yes
Dropbox kludge: No
Force volume uid/gid: Yes
afpd.conf: /etc/netatalk/afpd.conf
AppleVolumes.system: /etc/netatalk/AppleVolumes.system
AppleVolumes.default: /etc/netatalk/AppleVolumes.default
UAM search path: /usr/lib/netatalk/
- Oct 20, 2020Retired_Member
