roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
mdgm-ntgr
Feb 15, 2010NETGEAR Employee Retired
rezonat0r wrote:
If Netgear can't even reproduce this obviously common problem... well... I get the sense that the NV's are collecting dust while they all use their shiny new Intel boxes.
NetGear has introduced some fixes for x86 ReadyNas and should be able to compile similar fixes for the older Sparc ReadyNas (if necessary). NetGear is working on 4.1.7, which is expected to be released sometime soon (hopefully).
NetGear can try and do workarounds etc. to limit problems, but if netatalk lacks some features, there's only so much NetGear can do without a newer version of netatalk.
- Oct 20, 2020Retired_Member
