roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
lasseoe
Mar 20, 2010Aspirant
mdgm wrote:
rezonat0r wrote:
NetGear has introduced some fixes for x86 ReadyNas and should be able to compile similar fixes for the older Sparc ReadyNas (if necessary). NetGear is working on 4.1.7, which is expected to be released sometime soon (hopefully).
NetGear can try and do workarounds etc. to limit problems, but if netatalk lacks some features, there's only so much NetGear can do without a newer version of netatalk.
That's not how things work, if a company ships a product they are obligated to fix it within warranty regardless of what the issue is, they can't just blame it on a hardware or software supplier. You're saying that because an opensource product is used in a commerical product (and not a cheap one) the company can sit back and say "not our fault" ? No no, they have to fix it, it's not the customers fault that they chose netatalk, or whichever other product it could have been opensource or not, it's also not netatalk's problem, it's entirely opensource, you can use it or not and on your own risk, and "own risk" that's NetGear/Infrant here. If you buy a new car and it rusts within a year, the dealership or factory can't tell you that it's because they bought bad paint and you should take it up with the paint supplier, or wait a year and maybe we'll have a solution for you.
I'm certain NetGear are doing all or well something to fix a lot of the bugs, but it's imho not quite good enough, in particular as they sold the ReadyNAS 1100 as being meant for business use.. yeah right.
- Oct 20, 2020Retired_Member
