roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
rezonat0r
Mar 20, 2010Aspirant
lasseoe wrote:
mdgm wrote:
NetGear can try and do workarounds etc. to limit problems, but if netatalk lacks some features, there's only so much NetGear can do without a newer version of netatalk.
You're saying that because an opensource product is used in a commerical product (and not a cheap one) the company can sit back and say "not our fault" ?
Actually, Netgear has not said anything. That's the problem :D
- Oct 20, 2020Retired_Member
