roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
sphardy1
May 24, 2011Apprentice
pb10006 wrote:
My last back up with time machine was April 15, and -every- backup attempt from any of my three Macs simply fails for the beforementioned reasons.
You are responding to a thread that has been dead for over 1 year, has 5 pages of responses and there has been at least 1 firmware update made for every ReadyNAS product since the last comment. Maybe you could be more explicit, even open your own thread, rather than expect people to go through all that info to figure what your issue might be?
Yes, I'm seeing the error posted in the Mac logs, and yes, I'm seeing unrecoverable TCP errors in the ReadyNAS logs.
TCP errors would suggest networking problems.
Presently the combination of a NetGear ReadyNAS+ and Macs is simply not working altogether, so either NetGear retracts support for Macs and refunds all those involved, or fixes the problem ASAP.
You have a problem so all Mac users should be refunded? Seriously?
I appreciate your comments may be borne of frustration, but if you really want to solve this - please create a topic with full details of the problem you are having, your setup, software/firmware/OS versions etc and what you have already tried to fix the problem. Then you may get a more informative & helpful response
- Oct 20, 2020Retired_Member
