roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
pb10006
May 24, 2011Aspirant
I'm fine with working directly on my backup machine [ ... linux is linux, right :) ]. do you know which file(s) need to be tossed? i take it such files are re-created whenever time machine posts the next update, right?
the worst that can happen is that i'll lose my history ...
cheers,
p.
cheers,
p.
- Oct 20, 2020Retired_Member
