thegoose
Aug 12, 2014Aspirant
perl relocation error; undefined symbol
nas:~# perl -v This is perl, v5.8.8 built for sparc-linux Copyright 1987-2006, Larry Wall Perl may be copied only under the terms of either the Artistic License or the GNU General Public Lic...
mdgm-ntgr
Aug 13, 2014NETGEAR Employee Retired
Some things such as perl shouldn't be updated.
Did you do an?:
Doing that is not a good idea and will break things.
So you should make sure your backup is up to date and if an OS re-install doesn't fix it, you should do a factory default (wipes all data, settings, everything).
Did you do an?:
# apt-get upgrade
