mcbmail
Feb 29, 2012Aspirant
Permission Problems on an "open" CIFS share.
We have a ReadyNas 1100 with the following settings: 1. Security Mode: User (in our Workgroup) 2. Users are mainly set up for their own personal storage and quotas. There are some shares that onl...
ReadySECURE
Feb 29, 2012Apprentice
StephenB is correct about the firmwares. The 4.2.x series is designed for x86 based units, and the Sparc based units have the 4.1.x firmwares designed for them.
Checking the 'set ownership and permission for existing files should reset the share permissions. As StephenB has mentioned, this is a command so it will appear as though nothing happened (cleared or reset fields) but there will be a message that says that the permissions have been set.
