mcbmail
Feb 29, 2012Aspirant
Permission Problems on an "open" CIFS share.
We have a ReadyNas 1100 with the following settings: 1. Security Mode: User (in our Workgroup) 2. Users are mainly set up for their own personal storage and quotas. There are some shares that onl...
Mar 02, 2012Guru - Experienced User
Has anyone at Netgear thought about having a "permissions reset" option in the scheduled Volume Consistency Check? Wouldn't help the sparc-based products of course, but might eliminate some of the pain that results from the permission problem.
readysecure1985 wrote: There are so many variables that could cause this to happen (I've seen a Windows 7 machine override security settings). The cause for this particular case is unknown and would be extremely difficult to determine. However, now you know how to correct the issue when it arises in the future (which hopefully it doesn't).
