dim73
Nov 29, 2012Aspirant
Permissions Issue
Hi, Yesterday I have copied a HD to a specific folder on my NAS using the backup function. While configuring the backup job, I failed to do it correctly and forgot to tick the "change ownership"...
a_burger_with_f
to set the permissions you would have 2 ways to go about it if it is not joined to a domain then just
-go to the share and add the users that you want to have access to it and separate by ( , )
if you set guest access then it will let you in even if you are not a user
if it is joined to a domain
then go to your dc and access the shares via ciffs and right click and go to properties then security
and you would set them through there
