maverick56
Jan 21, 2012Aspirant
PHP 5.3 installation
Hi, I found many tuto to install PHP on ReadyNas Duo, but none for PHP 5.3 ... Do you know if it's possible ? Merci
mdgm-ntgr
Jan 21, 2012NETGEAR Employee Retired
Which Duo do you have? See How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2
If you have the v1, take a look at http://www.readynas.com/forum/viewtopic.php?f=47&t=54543
If you have the v2, take a look at http://www.readynas.com/forum/viewtopic.php?f=147&t=59441
