maverick56
Jan 21, 2012Aspirant
PHP 5.3 installation
Hi, I found many tuto to install PHP on ReadyNas Duo, but none for PHP 5.3 ... Do you know if it's possible ? Merci
mdgm-ntgr
Jan 22, 2012NETGEAR Employee Retired
The V1 is Debian sarge. So using apt-get to install PHP 5.3 is not an option. You'd need to compile from source or possibly even backport it depending on its dependencies etc.
When did you purchase your Duo?
