maverick56
Jan 21, 2012Aspirant
PHP 5.3 installation
Hi, I found many tuto to install PHP on ReadyNas Duo, but none for PHP 5.3 ... Do you know if it's possible ? Merci
mdgm-ntgr
Jan 22, 2012NETGEAR Employee Retired
If you had only just purchased it, I would've suggested checking to see if your reseller accepts change of mind returns. The new Duo v2 is on Debian Squeeze so is far more up to date in what packages can easily be installed on it.
Frontview (web-interface) of the Duo v1 depends heavily on the old version of libc. Updating to a newer version of Debian would break this.
