newtonwb
Mar 01, 2015Aspirant
PHP GD Library and Ioncube help!
I have a new RN-314 and I want to use it as a webserver.
I have installed PHP from the Apps section.
I need to install the GD Library. Can anybody help with this?
Also, I need to install IONCUBE. I also need help with this...
Any help would be appreciated!
- super_poussinVirtuosoGD should be in it
- newtonwbAspirantHello super-poussin,
I have resolved both of these items.
I installed PHP, PHPMyAdmin, and MySQLServer from the FrontView:Apps section (I believe that all of these were by you! Thanks!).
I also used your SSH app - and through a myriad of searching I found how to install GD using the get-apt (can't remember the rest).
Then found some useful info on how to install ioncube.
I'm not exactly sure about what I'm doing/did, but it is working...
Thanks for the Apps!
