Sushiboy
Aug 12, 2014Aspirant
Pinging from ReadyNAS Duo
Issue: Transmission no longer seen as seeding torrents to a private tracker. I need to be able to ping the tracker from the NAS. How do I do that?
mdgm-ntgr
Aug 16, 2014NETGEAR Employee Retired
I suspected you could be encountering an issue as a result of staying on an old version of software while others move to newer versions of software.
Have you tried rebooting the NAS?
How is the I.P. set on the NAS? Is it set to automatically receive an I.P. address or is it static? If the latter have you checked to see that the DNS and Gateway settings are correct?
Can you email me your logs?: http://readynas.com/kb/faq/misc/how_do_i_send_all_logs
If you want to ping from the NAS you could install EnableRootSSH and SSH in as 'root' (no quotes - password initially set to be the same as that for the admin user) using PuTTy on Windows or the Terminal on Mac/Linux.
