Sushiboy
Aug 12, 2014Aspirant
Pinging from ReadyNAS Duo
Issue: Transmission no longer seen as seeding torrents to a private tracker. I need to be able to ping the tracker from the NAS. How do I do that?
Sushiboy
Aug 16, 2014Aspirant
I discovered by disabling ReadyNAS Remote that it was the culprit and apparently causing a conflict with Transmission. So that problem is isolated but not resolved.
Thanks for the recommendation on EnableRootSSH. Being a Mac user I'm not at all competent with command line stuff (big mystery to me). There isn't another app I can install with a simple intuitive GUI that will do what I need?
