Sushiboy
Aug 12, 2014Aspirant
Pinging from ReadyNAS Duo
Issue: Transmission no longer seen as seeding torrents to a private tracker. I need to be able to ping the tracker from the NAS. How do I do that?
Aug 16, 2014Guru - Experienced User
If the trackers or the peers you are connecting with use 5.x.x.x addresses, there is an IP address conflict - since remote hijacks the 5.x.x.x address space.
Sushiboy wrote: I discovered by disabling ReadyNAS Remote that it was the culprit and apparently causing a conflict with Transmission. So that problem is isolated but not resolved.
If that is the cause, there is no workaround other than disabling remote.
