mrQQ
Jun 19, 2015Apprentice
Please help me understand my used space
Hi, I have 2 2TB drives in the system. If I do `du -s /data` I get the used space as 154277424272. If I do a `df` I get used space as 1731570392. The difference is almost 200GB! Where does it go...
Jun 20, 2015Guru - Experienced User
Yes, that will give you more information than df. If you want to compare with df, you might want to add -k to use KiB units.
# btrfs fi df /data -k
