mrQQ
Jun 19, 2015Apprentice
Please help me understand my used space
Hi, I have 2 2TB drives in the system. If I do `du -s /data` I get the used space as 154277424272. If I do a `df` I get used space as 1731570392. The difference is almost 200GB! Where does it go...
Jun 22, 2015Guru - Experienced User
Also, did you confirm that du was processing the hidden files in \data (in particular \data\.apps)?
Note that existing snapshots are not deleted when you turn them off.
