mrQQ
Jun 19, 2015Apprentice
Please help me understand my used space
Hi, I have 2 2TB drives in the system. If I do `du -s /data` I get the used space as 154277424272. If I do a `df` I get used space as 1731570392. The difference is almost 200GB! Where does it go...
mrQQ
Jun 23, 2015Apprentice
I deleted snapshots manually.
I would like to believe du shows correct info, as that is exact same thing I see when looking via samba at /data (as i've said, .apps is around 350MB).
