mrQQ
Jun 19, 2015Apprentice
Please help me understand my used space
Hi, I have 2 2TB drives in the system. If I do `du -s /data` I get the used space as 154277424272. If I do a `df` I get used space as 1731570392. The difference is almost 200GB! Where does it go...
mrQQ
Jun 23, 2015Apprentice
mdgm wrote: Maybe it would help if I could take a look (sent you a PM about this) and/or if you can send me your logs (see The Sending Logs link in my sig). Probably easier than asking for a series of commands.
Looks like you have a lot of metadata.
I wonder if you are using snapshots. In the web interface you should see any snapshots when you go to Shares and look at the Timeline.
I will let you have a look, indeed will be much faster.
