mrQQ
Jun 19, 2015Apprentice
Please help me understand my used space
Hi, I have 2 2TB drives in the system. If I do `du -s /data` I get the used space as 154277424272. If I do a `df` I get used space as 1731570392. The difference is almost 200GB! Where does it go...
mdgm-ntgr
Jun 24, 2015NETGEAR Employee Retired
df and du are calculating space usage using different methods.
Furthermore df and du are not designed for use with BTRFS. btrfs fi df is designed for use with btrfs.
