mrQQ
Jun 19, 2015Apprentice
Please help me understand my used space
Hi, I have 2 2TB drives in the system. If I do `du -s /data` I get the used space as 154277424272. If I do a `df` I get used space as 1731570392. The difference is almost 200GB! Where does it go...
mdgm-ntgr
Jun 25, 2015NETGEAR Employee Retired
I've got some feedback from some colleagues.
You may find this explanation useful: http://www.spinics.net/lists/linux-btrfs/msg39960.html
df and du are using different methods to calculate how much space is used.
btrfs df is using metadata to calculate whereas df is doing a raw lookup. btrfs df can take into consideration mounted snapshots and home shares. The snapshots will take up some space and du will not show this.
du isn't a good tool to use with btrfs to see how full the filesystem is.
df doesn't know about compression on btrfs level or an unbalanced filesystem so it's not accurate.
