mrQQ's avatar
mrQQ
Apprentice
Jun 19, 2015
Please help me understand my used space
Hi,
I have 2 2TB drives in the system.
If I do `du -s /data` I get the used space as 154277424272. If I do a `df` I get used space as 1731570392. The difference is almost 200GB! Where does it go?
  • I've heard that and I understand that. The question is, what is taking up 175GB which is not visible anywhere, not even using btrfs tools?
  • StephenB's avatar
    And I think mdgm is saying he doesn't know, but suspects part of the issue is that du isn't accurate with btrfs. I don't think you will get any other answer here.
ProSupport for Business
