DADsNAS
Jan 04, 2017Tutor
PLEX Won't run/load on RN316 after upgrade to 6.6.0 - AGAIN
Again, Plex dissappeared from my system when I tried to do a manual update to Plex Media Server. I was running 1.2.2.2 and tried to update to 1.3.3.3 when Plex dissappeared and now it will not let me...
- Jan 04, 2017
Using Firefox, I was able to get Plex re-iinstalled on my system.
Thank you to everyone for their help.
Now i just have to remember to us Firefox in the future.
Dennis
DADsNAS
Jan 04, 2017Tutor
The error message is 'Cannot Install application'.
When I was on the Plex site, I saw that there was an update. So I downloaded it and when I tried to do a manual update on the RN316, The RN316 responded with the 'Cannot Install Application' message and then removed Plex Media Server from my system. Any attempts to re-install garner the same message.
As far as version 6.6.1 being available, when I ask my system to 'check for updates' it tells me that my current version (6.6.0) is the latest.
Thank you for the response,
Dennis
bedlam1
Jan 04, 2017Prodigy
Download 6.6.1 from Here unzip it, then do a manual firmware update in NAS UI System/Settings and up load the .IMG file
- DADsNASJan 04, 2017Tutor
Sucessfuly downloaded and installed 6.6.1. Thank you.
The only difference when trying to install Plex is that now I get a window opening indicating that the install is starting. However, the result is still the same: Cannot install application D:\dademet\Download\PlexServer\RN31600\plexmediaserver-ros6-binaries_1.3.3.3148-b38628e_amd64.deb.
Still unable to get Plex installed, again.
- StephenBJan 04, 2017Guru - Experienced User
Are you using edge? IF so try chrome or firefox.
This might be the issue that WhoCares_ reported (Edge sending the full path name to the NAS server on upload instead of just sending the file name itself).
I am not using Edge. I am using IE v11.
I have Firefox, I will try that. Thank you.
