jackburton
Mar 03, 2017Tutor
Poor Performance on ReadyNas 2120 - firmware 6.6.1
Hi all, this is the result of a test with Nas Performance Tester 1.7 : NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on \\SITEP-NAS\Sofware...
- AnonymousMar 03, 2017
Putting the address of router as dns server might help.
jackburton
Mar 03, 2017Tutor
Hi,
antivirus is already disabled,
connection is gigabit,
disks installed are 4 X Seagate Constellation ES.3, tot. 4 x 2GB in RAID 5 configuration
mdgm-ntgr
Mar 03, 2017NETGEAR Employee Retired
Which services are you running?
Which apps do you have installed?
Can you try disabling IPv6?
- jackburtonMar 03, 2017Tutor
Active Services are:
SMB
AFP
HTTP
HTTPS
No installed apps.
IPV6 already disabled on the connected interface.
Can't disable it on the other disconnected interface because it seems it can't keeps setting changes
Another test:
----------------------------- Running warmup... Running a 400MB file write on \\SITEP-NAS\Sofware 5 times... Iteration 1: 11,81 MB/sec Iteration 2: 11,82 MB/sec Iteration 3: 11,84 MB/sec Iteration 4: 11,83 MB/sec Iteration 5: 11,81 MB/sec ----------------------------- Average (W): 11,82 MB/sec ----------------------------- Running a 400MB file read on \\SITEP-NAS\Sofware 5 times... Iteration 1: 10,56 MB/sec Iteration 2: 10,80 MB/sec Iteration 3: 11,43 MB/sec Iteration 4: 11,49 MB/sec Iteration 5: 11,57 MB/sec ----------------------------- Average (R): 11,17 MB/sec -----------------------------
- mdgm-ntgrMar 03, 2017NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
Done,
Thankyou.
