jackburton
Mar 03, 2017Tutor
Poor Performance on ReadyNas 2120 - firmware 6.6.1
Hi all, this is the result of a test with Nas Performance Tester 1.7 : NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on \\SITEP-NAS\Sofware...
- Retired_MemberMar 03, 2017
Putting the address of router as dns server might help.
jackburton
Mar 03, 2017Tutor
I'm using the nas on a local sub-network, i have no dns servers.
Retired_Member
Mar 03, 2017Putting the address of router as dns server might help.
- jackburtonMar 03, 2017Tutor
I configured my network settings using nas address as dns and gateway, restarted nas, and now it can transfer at 120 MBytes/s,
Thank you very much for your support.
- StephenBMar 06, 2017Guru - Experienced User
The gateway should be the router, not the NAS itself. The DNS server should match what your PC's are using - generally the router IP. 8.8.8.8 will also work for DNS (it's google's public DNS server).
Your settings might fix your performance problem, but using the NAS address as the gateway and DNS server will create other issues (firmware updates will fail among other things).
- jackburtonMar 06, 2017Tutor
Good Morning,
the ReadyNas is placed in an isolated network, without gateway so at the moment this configuration works fine for me.
Thank you.
Bye.
