Weevil1
Mar 14, 2014Aspirant
Poor streaming connection/speed
ReadyNAS NV+ v2 WNDR4500 2 x Powerline AV500 Tvix N1 Network Player Hello. My first post at the ReadyNAS forum (previous Stora owner!). I hope someone can help me; I'm getting really frustra...
Mar 16, 2014Guru - Experienced User
Weevil wrote: I've run NASTester a few times from the player end of the network and it is only reading at 4.2 MB/sec (writing to the NAS is at 7.6 MB/sec)?! Am I right in thinking that this is way too slow... despite 'upgrading' to the newer Netgear AV500 Powerlines, would it make more sense to go wireless?
(a) Powerline is a hit-or-miss technology. It works well on some circuit pairs, but not so well on other circuit pairs. If you have the XAVB5602, then try using a power adapter that drops the ground lead. I beta-tested that model, and on some circuits that gave better performance.
(b) 802.11n might give better performance than powerline, it is worth testing.
Look on the NAS network interface configuration. There is a pulldown to select 100 mbit. You don't need to do anything in the router.
Weevil wrote: I can't see any options on the router to enable 100mbit/s networking. I'll have another search through the www later tonight or tomorrow.
Though the test should ideally would be done w/o using the powerline adapters.
Also, make sure your powerline adapters are not plugged into surge protectors.
