Weevil1
Mar 14, 2014Aspirant
Poor streaming connection/speed
ReadyNAS NV+ v2 WNDR4500 2 x Powerline AV500 Tvix N1 Network Player Hello. My first post at the ReadyNAS forum (previous Stora owner!). I hope someone can help me; I'm getting really frustra...
Mar 23, 2014Guru - Experienced User
Those are fine settings, though I'd probably keep speed & duplex on audio.
On the disk fullness - do you have an SATA spare disk lying around? If so, you could a test with a clean install, and see how that compares.
You'd
(a) power down the NAS,
(b) remove the disks, labeling them by slot
(c) install just the temporary disk and power up
That will create a clean install that you can test.
Then shut the NAS down, and restore the original disks to get back to your current state.
You'd
