mitumix
Sep 17, 2014Aspirant
Port forwarding 443
I want to remote access the Management GUI. I put the port forwarding (443 ssl) on my router to my nas. I cant access my NAS :( Does anyone know which ports/group of ports NAS DUO work. My r...
Sep 17, 2014Guru - Experienced User
Also check to make sure your ISP doesn't block 443. http://www.canyouseeme.org/ will let you do that.
