Scubbie
Feb 21, 2012Apprentice
Portforwarding with ReadyNAS Ultra 2 Plus and DGND3700
I am wondering if someone can spot what I have done wrong please and provide some guidance to resolving this issue I have. I have a ReadyNAS Ultra 2 Plus and a DGND3700. Using FileZilla I can access t...
Feb 21, 2012Guru - Experienced User
ok, I hadn't scrolled your logs enough to see that. Sorry.
Scubbie wrote: Thank you for your response StephenB.
Unfortunately that seems to be what I had selected.
What is odd about the two traces is that you are using very different passive ports.
-The local log on uses port 37575 [Response: 227 Entering Passive Mode (192,168,xx,xx,146,199)] (146*256+199 => 37575)
-The internet log on uses port 53093 [Response: 227 Entering Passive Mode (192,168,xx,xx,207,101)] (207*256+101 => 53093)
This suggests that perhaps the passive port range configured on the NAS is too large? All the passive ports configured on the ReadyNAS must be forwarded to the NAS in the router. I have 4 passive ports configured, which works ok for me (I normally only have one FTP connection running at a time).
