grahambeale1
Feb 10, 2012Aspirant
Possible?: Upgrading from Duo v1 to NV+ v2
Hi guys, I am increasingly running out of space on my old Duo and there isn't any way to expand this device any further (or not that I am aware of). If I bought an NV+ 2 or maybe something bigger....
Mar 11, 2012Guru - Experienced User
Yes, though it is best if the Duo drives are also on the ultra HCL. If you like, you can delete the partitions (by connecting the drives to a PC) as you move them to the Ultra - that ensures that the ultra will see them as new.
Issemann wrote: OK, the USB backups kept failing and I got fed up that method all together. I decided to connect the new ReadyNAS Ultra 2 to my network and see if a NAS-2-NAS backup would fair better. I purchased a copy of your guide (very nicely written, by the way!) and set up the backup jobs as you described. They are running as I type this, but the guide never spoke about migrating the drives after the backup completes. Allow me to explain....
My old ReadyNAS is a Sparc Duo and the new ReadyNAS is a x86 Ultra 2. I have 2x1TB drives in the Duo and a spare 1TB drive (for backups). Here is the plan I was hoping to follow....
1) Install the spare drive into the Ultra 2
2) Copy my files from the Duo to the Ultra 2
3) Remove one drive from the Duo and install it into the Ultra 2
4) Mirror the drives in the Ultra 2 and let them sync up
5) Remove the second drive from the Duo and keep it in a safe place as a backup
Is this possible?
