michelkenny
Sep 26, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread for easy comparison.
You can run IO Meter by following the steps here: http://www.infrant.com/forum/viewtopic.php?t=265
Please post your hardware specs, other relevant info, and IO Meter results. Maybe this could get stickied? Or ignored if no one cares :)
Here's my info:
Stock NV
4 x Seagate ST3250823AS 250gb Hard Disk in X-RAID
All journaling disabled
Fast writes on
Intel D805 2.66ghz dual core cpu
Intel D945GNTLKR motherboard with onboard Intel Gigabit NIC
2 gigs ram
Seagate ST3250824AS 250gb Hard Disk
Windows Vista x86 RC1 (if that makes a difference)
Dell PowerConnect 2708 Gigabit switch (no jumbo frames)
Cat 6 cabling
IO Meter Write: 19.321793 MBps
IO Meter Read: 26.803979 MBps
Here's my info:
Stock NV
Fast writes on
2 gigs ram
Cat 6 cabling
- bbaraniecLuminary
chirpa wrote: bbaraniec wrote: ReadyNas NV+ 4.01b1-p2-T10 [1.00a042] 1024 MB [ 2.5-3-3-7 ]
Time to update that firmware ;) There is a newer beta out.
I wanted wait till final version :lol:
Wlihe upgrading firmware my settings will stay? What about addons? - lacika76AspirantHi bbaraniec!
It's a fantastic result!
What kind of file system could you get these result:
"38 MB/s write (PC->Nas)
43 MB/s read (Nas->PC)"
I can reach about 35-36MB/s with my two drives config, but the read speed far from your result.
I've a question about four drive configuration. It's every time faster than two drive config? Chirpa what do you think?
Thanks,
Lacika76 - WebaccessAspirantReadyNAS Setup
ReadyNAS NV+
4 - Seagate ST31000340NS 1TB hard disks, 32 MB cache
RAIDiator 4.00c1-p2
Enable jumbo frames: On
Disable full data journaling: Grayed out
Disable Journaling: On
Optimize for OS X: Off
Enable fast CIFS writes: On
Enable fast USB disk writes: Off
UPS: Not present
PC Setup
ADM Athlon64 X2 Dual Core 4200+
4 GB Memory (3GB Memory seen by OS)
Windows XP Pro, Service Pack 3
NVIDIA nForce NIC, Jumbo frame 9000 bytes, Optimized for Throughput, Drive version 50.2.5.0
Network Setup
Switch: NETGEAR GS108, 16Gbps non-blocking backplane, Jumbo Frame Support (9000)
IOMeter Results
Test: 256KB Sequential Read, and 256KB Sequential write pattern
Read: 37.76 MB/s
Write: 43.50 MB/s - vilden66AspirantHi Guys,
This was all I came up with. :x
IOMeter Results
Wireless
Read: 0.15 MB/s
Write: 1.14 MB/s
Wired cat.5
Read: 1.29 MB/s
Write: 3.78 MB/s
I have the following Setup:
ReadyNas Duo
Amilo 1520 Core2Duo Vista SP1 leatest firmwear on both wire and wireless NIC
Linksys WRT54G latest firmwear
I found this faults reported in networktab
Auto-negotiation 3
Bad packets 0
Disconnect 3
False carrier 68
Idle errors 0
Link failures 0
Receive errors 0
Symbol errors 0
VLAN tags 0
TCP Retransmits 422
Unrecovered TCP Retransmits 101
Please, help someone...
/vilden - PlukkieAspirantVilden,
Don't use cat.5 cabling if you connect at gigabit speed.
Use cat5e or cat6 else you get interference of signals, which cause drops and resends, which lowers your throughput. - vilden66Aspirant
Plukkie wrote: Vilden,
Hi Plukkie,
Do you mean that I cant use cat.5 because I have gigabit on the NAS?
My router doesen't support gigabit at all, nore do my laptop. The NAS identify the network as 100 Mbit full duplex.
Before I installed the Duo I had a Qnap TS-109, worked like a charm.
/vilden - bavmanAspirantVaio SZ 2.0ghz w/ 2gig of RAM - Vista Business SP1
Running the latest radiator (got the device on Tuesday) - 2x750gb
Jumbo Frames Off
All journaling Options Off
mtu = 1496
Netgear DG834GT (54mbps wireless)
Read/Write - Wireless 2.5mbps
Read/Write - Ethernet - 6mbps.
Bought the NAS purely so i could get rid of my external hd and create some space on my desk - itunes streaming fine (only me on the network so don't need the server)
Anyone know of a special way to squeeze out a few extra mbps? - bbaraniecLuminaryFrom wireless you will not get much more, since you running b/g.
Wired network:
- enable jf
- read this, no point to copy/paste it :) http://www.readynas.com/?p=310 - mike_AspirantHad my ReadyNas DUO now for a while and love it.
Ran the performance test with the following configuration.
Readynas Duo
RAIDiator 4.1.4
(upgraded ram to 1024MB) Crucial CT12864X335
1 x Seagate ST3500320AS 500GB
1 x Seagate ST3500630AS 500GB in X-RAID
All journalling disabled
Fast writes on
P.C.
Intel E6750 2.66ghz
4GB RAM
GIGe Ethernet
Windows Vista x86 SP1
NETGEAR GS116 ProSafe 16-Port Unmanaged Gigabit Ethernet Switch (no jumbo frames)
Cat 5e cabling
Using IO Meter config as per front page
IO Meter Write: 30.044067 MBps
IO Meter Read: 42.544788 MBps - damianpAspirantNV 1 GB ram RAIDiator 4.1.4
AFP, 4 X 500Gb
Gig E Linksys and Gig E Airport
OS X 10.5.5 iMac Gig E client running X Bench
Sequential
Uncached Write 7.32 4.50 MB/sec [4K blocks]
Uncached Write 57.80 32.70 MB/sec [256K blocks]
Uncached Read 20.73 6.07 MB/sec [4K blocks]
Uncached Read 124.83 62.74 MB/sec [256K blocks]
Random
Uncached Write 40.14 4.25 MB/sec [4K blocks]
Uncached Write 98.66 31.58 MB/sec [256K blocks]
Uncached Read 829.61 5.88 MB/sec [4K blocks]
Uncached Read 335.23 62.20 MB/sec [256K blocks]
Running a real file copy of a VMware image from the NV gave me a consistent 49 MB/s
Doing a write to the NV gave me a relatively consistent 27MB/s
Kudo's to the developers!! AFP rocks on RAIDiator 4.1.4.
