michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread for easy comparison.
You can run IO Meter by following the steps here: http://www.infrant.com/forum/viewtopic.php?t=265
Please post your hardware specs, other relevant info, and IO Meter results. Maybe this could get stickied? Or ignored if no one cares :)
Here's my info:
Stock NV
4 x Seagate ST3250823AS 250gb Hard Disk in X-RAID
All journaling disabled
Fast writes on
Intel D805 2.66ghz dual core cpu
Intel D945GNTLKR motherboard with onboard Intel Gigabit NIC
2 gigs ram
Seagate ST3250824AS 250gb Hard Disk
Windows Vista x86 RC1 (if that makes a difference)
Dell PowerConnect 2708 Gigabit switch (no jumbo frames)
Cat 6 cabling
IO Meter Write: 19.321793 MBps
IO Meter Read: 26.803979 MBps
Here's my info:
Stock NV
Fast writes on
2 gigs ram
Cat 6 cabling
- starg4zeAspirant
sfg wrote: Bernhard Hartl wrote: sfg wrote: I recently received my readynas pro business and while I am liking it I have not been getting anywhere near the speeds as it seems are possible.
I am getting drag and drop read and write speeds of about 4-6MB/s. I have been trying the various stuff reported here but nothing is seeming to cause much difference.
The only way to get the full performance of the readynas pro is to connect via GigaBit LAN
You have to use a good GBit Switch and CAT6 cables for connecting the computers and the NAS to the switch
WLAN is always slow - that's not a problem of your NAS but a problem of WLAN
Even when connecting at full N speeds?
I was hoping for 20s or so even using wlan.
I manage to get 8-9MB/s over AFP using my MacBook Pro and a Timecapsule (both supporting 803.11n). You you won't see much better figures unless you are in an isolated area with no interference from other WLANs around you(or microwave ovens...) and sitting next to your AP with your computer. - emonkiaAspirantI am easily seeing write speeds of 50MB/sec. I have journaling on, and I am not using Jumbo frames. I think with a small amount of optimization, I could max out the NICs or the CPUs on the ReadyNAS, but either should be considered "really good" speed.
Sample rsync transfer of a few compressed LUN copies (HDD images):Number of files: 48
Number of files transferred: 25
Total file size: 21878830041 bytes
Total transferred file size: 21878829859 bytes
Literal data: 21878829923 bytes
Matched data: 0 bytes
File list size: 1130
File list generation time: 0.028 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 21881503093
Total bytes received: 704
sent 21881503093 bytes received 704 bytes 55607379.41 bytes/sec
total size is 21878830041 speedup is 1.00
---- 2009-03-19 19:21:40 finish rsync
rsync server:
ReadyNAS Pro
HDD - 6x 1.5 TB Seagate (write cache on)
RAM - 4 GB
NET - 2x 1 Gb 802.3ad LACP bonded NICs
Journaling: on
Jumbo frames: off
switches:
Cisco ethernet - 3750G
Cisco fiber - 9124
rsync client:
IBM HS20 8843 Blade server
CPU - 2x 3.0 GHz Intel Zeon (HT)
RAM - 4 GB
HDD - SAN - LUN Raid5(3) via QLogic 2312 1x 2 Gb Fiber to Xiotech Mag3D 48 drive (non-idle)
OS - Ubuntu v6.06
rsync compression was off, not using SSH
I am easily able to pull 150 MB/sec with this machine, and depending on the current SAN load it can peg at around 200 MB/sec (SAN has faster IO than server's 2 Gb Fiber connection). The above was done while SAN was under normal load, with no configuration changes done to optimize speeds (standard everyday setup). I also transferred a much larger data set than the RAM in the ReadyNAS, so full caching was not a factor for speed shown.
This Pro just flat out blows the doors off the NV+ (as expected). If you need speed, get the Pro. - rstoneAspirantI guess I'll add my results as well...
ReadyNAS Pro Business Edition:
3072 MB RAM
6 x 1000 GB WD10EACS
Fast writes on
Jumbo Frames On (9000)
Dual Gigabit (Teamed using 802.3ad w/LACP)
Switch:
HP Procurve 1800
Test Machine:
EVGA X58 w/Intel Core i7 at 2.7Mhz
6 GB Corsair Memory at 1600Mhz
2x WD Raptors (RAID 0)
Vista x64
Intel Pro/1000 Dual PT NIC w/ Jumbo Frames Enabled at 9k
IOMeter Results:
Test: 256KB Sequential Read / 256KB Sequential Write
Read: 65.16 MB/s
Write: 94.35 MB/s
Real World Results: (Using copy & paste w/5 GB file)
Read: 109 MB/s
Write: 110 MB/s - I ran some speed tests while I was trying to figure out all the crap about MTUs. I just copied and pasted from my other post (viewtopic.php?f=28&t=26902).
Hi Everyone!
Since no one responded I just went ahead with some trials. No offense taken because the post was LONG! :lol:
Before I give my test results here is my set up:
MBP (early 08, mac os x 10.5.6)
D-LINK DIR-655 Wireless Router (supports jumbo frame-9000, from my extensive research and Gigabit LAN ports, but MTU value is set @ 1492)
D-Link DGS-2205 (Gigabit Switch, also supports jumbo frame-9000, http://www.newegg.com/Product/Product.a ... 6833127083)
ReadyNAS Duo (MTU 7936)
Hostname: ReadyNAS
Model: ReadyNAS Duo [X-RAID]
Serial:
Firmware: RAIDiator 4.1.4 [1.00a042]
Memory: 256 MB [2.5-3-3-7]
IP address: 192.168.0.199
Volume C: Online, X-RAID, 2 disks, 76% of 925 GB used
All day I've been reading other people's post in regards to performance Mac/PC, ReadyNAS Duo/PRO... I've been messing around with the MTUs and file sizes. Here we go.
I did my best to get the numbers.
Note: The way I changed my MTU values were via Terminal by using the "sudo ifconfig en0 mtu" command. I double, triple checked MTU values before, after and during the file transfers. All of the file transfers were drag & drop over AFP.
Test 1
MBP MTU: 1500
NAS MTU: 7936
File Size: 4.25 GB
Read (from NAS to MBP): Average 42.1 MB/s, Peak 43.0 MB/s, Range 34 MB/s to 42 MB/s
Write (from MBP to NAS): Average 9.5 MB/s, Peak 11.1 MB/s, Range 9 MB/s to 11 MB/s
Test 2
MBP MTU: 7936
NAS MTU: 7936
File Size: 4 GB
Read (from NAS to MBP): Range 36 MB/s to 37 MB/s
Write (from MBP to NAS): Range 9.5 MB/s to 10 MB/s
I thought this was really odd because there was no change in any of the transfer speeds. So, I unmounted the drives and remounted it and that's when the transfer speed kicked up!
Test 3
MBP MTU: 7936
NAS MTU: 7936
File Size: 8 GB
Read (from NAS to MBP): Peak 52.3 MB/s, Range 49 MB/s to 51 MB/s
Write (from MBP to NAS): Peak 41.1 MB/s, Range 38.3 MB/s to 40 MB/s
Nice!!! A huge increase, but I think the read speed got a big jump because the file size changed to 8 GB. Huge improvement over the write speed.
This time I wanted to restart the MBP and NAS because I wanted to clear any cache (just my guess...). So I restarted both the NAS and MBP and changed the MTU on the MBP to 9000 to see what would happen.
Test 4
MBP MTU: 9000
NAS MTU: 7936
File Size: 4 GB
Read (from NAS to MBP): Average 35.5 MB/s, Peak 41.5 MB/s
Write (from MBP to NAS): Average 40.4 MB/s, Peak 41.3 MB/s
The read performance had decreased (from 50s to 40s) so I assumed that it was because the MTU value on the MBP didn't match the NAS MTU. So I reverted back the MBP's MTU to 7936 and restarted only the NAS to clear any cache.
Test 5
MBP MTU: 7936
NAS MTU: 7936
File Size: 4 GB
Read (from NAS to MBP): Average 36.0 MB/s, Peak 43.9 MB/s
Write (from MBP to NAS): Average 40.2 MB/s
So basically, using MTU value of 9000 or 7936 on the MBP had not that much effect. No significant difference in the read speeds. But I tried copying a 8 GB file on the same setting from Test 5.
Test 6
MBP MTU: 7936
NAS MTU: 7936
File Size: 8 GB
Read (from NAS to MBP): Average 51.5 MB/s, Peak 53.2 MB/s
File Size: 4 GB
Read (from NAS to MBP): Range 45 MB/s to 50.8 MB/s
Write (from MBP to NAS): Average 39.4 MB/s
Test Conclusions:
1) It's my believe (guess) that the read speed when the MTU on the MBP (either 7936 or 9000) is largely depended on the size of the file. The bigger it is 4 GB> the faster the read speeds.
2) Write speed will significantly improve when you put the MBP's MTU to 7936 or 9000. I now always hit an average of 40 MB/s.
3) My guess is that you should always mount and remount the NAS whenever you change the MTU values on the MBP (see test 1, 2 and 3).
Still remaining questions :roll: :
1) Does using jumbo frames reduce performance when streaming videos from the NAS?
2) For some reasons the MTU values on the MBP do not stick. I still have to change it each time after restart. It will always return to default value of 1500. Anyone know how to make the new MTU value stick?
Thanks a lot everyone! - dbott67GuideI can't answer either of your questions, but I can provide a little info about the jumbo frames on the ReadyNAS. It is my understanding that the ReadyNAS really only utilizes jumbo frames when WRITING to the NAS. You will not see any performance gains while reading.
Performance does vary, as you've noticed. Some of the factors include: NAS settings (type of RAID, # of disks, journaling, etc), amount of RAM, file size, number of files, network protocol used and contention/congestion issues.
Your numbers are quite good and it looks like you've got it tweaked for maximum performance. Thanks for taking the time to post your findings.
-Dave - @ Dave
Thanks for the reply Dave! On this post and my other post!!! Hahaha... yes... it was very sad because it definitely seemed that I was talking to myself. :D
Much appreciated!
-Han - fishgeektedAspirantReadyNAS Duo - Factory Presets
Desktop 10/100 Windows XP SP 3
Laptop 10/100/1000 Wi/Fi B,G,N Windows Vista SP 1 64-bit Home Edition
Router D-Link DIR655 X-Treme N Gigabit
Iometer tests:
XP 10/100 Desktop Reads 9.27 MB/S and Writes 10.49 MB/S
Vista Wireless N Laptop (Wireless 130 mb/s connection) Reads 6.5 MB/s and Write 9.07 MB/s ( I have tried tweaking with many of the suggestions here and have only slowed the laptop)
I started doing these tests when I discovered the NAS was having a huge amount of TCP Retransmits and the laptop was timing out on accessing certain folders on the NAS...
Are these average speeds?
Thanks for your help, I'm still learning how to use the NAS! - dbott67GuideFor the XP 10/100 connection the numbers are very good (100 mbps = 12.5 MB/s which is the theoretical max; normal is 70-80% of that).
For wireless N, your number are also very good. Most people using wireless G get 2-3 MB/s and up to 6 using wireless N, so you're above that range.
-Dave - I've yet to test my Pro Pioneer on a network, I really wanted it to provide services more than remote file systems.
I've just upgraded from the stock 1Gig (4-5-5-15 667MHz) to 4Gig (6-8-8-18 800MHz) and I've seen some surprising speed boosts with raw IO to the disks..
Using hdparm -t -T /dev/c/c
Before upgrading RAM:
Timing cached reads: 1890 MB in 2.00 seconds = 945.13 MB/sec
Timing buffered disk reads: 510 MB in 3.00 seconds = 170.11 MB/sec
After upgrade:
Timing cached reads: 2350 MB in 2.00 seconds = 1175.62 MB/sec
Timing buffered disk reads: 550 MB in 3.00 seconds = 183.07 MB/sec
That equates to a 7% improvement buffered read and a 24% improvement cached read!
It would be really interesting to see how this NAS performs with load balanced Ethernet tests and multiple hosts but (without seriously trivial hacking) this feature is limited to the business model (frankly I think that is insulting on a $1400 NAS.. QNAP don't charge extra for load balancing or iSCSI :neener: )
Needless to say, I was surprised (and pleased!!) that a ram upgrade produced such an improvement! Best $60 spent!
There were some other performance questions:
Why a 32bit kernel? Not sure if 64bit would be better, but for TB systems I'd have though it possibly might be?
Why no hyper-threading. The Core2 Duo chip has two cores both used by the system. Both cores support hyper-threading but the kernel lacks support (it is turned off) Why wouldn't hyper-threading be enabled. I appreciate it is a minimal performance boost, but still.. - Macbook 10.5.6 (No Hacks)
Duo 256 mb - 2 x500gb (original seagates) (hacked sysctl)
Tested with Net Monitor transferring 3.5gb dvd iso
Receive 41.2 MB/s Peak 43.5 MB/s
Transmit 37.2 MB/s Peak 38.1 MB/s
2 Tcp Retransmit errors
