michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread for easy comparison.
You can run IO Meter by following the steps here: http://www.infrant.com/forum/viewtopic.php?t=265
Please post your hardware specs, other relevant info, and IO Meter results. Maybe this could get stickied? Or ignored if no one cares :)
Here's my info:
Stock NV
4 x Seagate ST3250823AS 250gb Hard Disk in X-RAID
All journaling disabled
Fast writes on
Intel D805 2.66ghz dual core cpu
Intel D945GNTLKR motherboard with onboard Intel Gigabit NIC
2 gigs ram
Seagate ST3250824AS 250gb Hard Disk
Windows Vista x86 RC1 (if that makes a difference)
Dell PowerConnect 2708 Gigabit switch (no jumbo frames)
Cat 6 cabling
IO Meter Write: 19.321793 MBps
IO Meter Read: 26.803979 MBps
Here's my info:
Stock NV
Fast writes on
2 gigs ram
Cat 6 cabling
- ScottChapmanApprenticeMy I am unimpressed with my new ReadyNas Pro 2. Here is my config:
2 new baracuda 7200.11 drives (on the HCL) - RAID 0
both NICs using LACP
Switch is a Dell Powerconnect 6024 w/jumbo frames enabled, and setup to use LACP for those NICs
Computer is home-built with dual 1Gbs teamed (also LACP)
On the drag and drop test I am seeing around 15MB/sec.
Yikes! - ghdstraightenerAspirantreally good way get the speed up,have to stick!!!!
http://www.ghdstraighteners-australian.com - cobelsAspirantWith 256 Mb memory.
CrystalDiskMark 2.2 (C) 2007-2008 hiyohiyo
Crystal Dew World : http://crystalmark.info/
Sequential Read : 33.061 MB/s
Sequential Write : 32.817 MB/s
Random Read 512KB : 19.201 MB/s
Random Write 512KB : 37.401 MB/s
Random Read 4KB : 0.520 MB/s
Random Write 4KB : 0.736 MB/s
Test Size : 500 MB
Date : 2011/05/08 15:26:49
With 1 GB memory.
Sequential Read : 34.167 MB/s
Sequential Write : 35.422 MB/s
Random Read 512KB : 34.273 MB/s
Random Write 512KB : 37.682 MB/s
Random Read 4KB : 4.843 MB/s
Random Write 4KB : 3.942 MB/s
Test Size : 500 MB
Date : 2011/05/15 19:05:28
Readynas Duo with jumbo frames enabled. What do you think, let me know. - loquaciousAspirantHi
I just transferred an avi file from my internal hard drive to the NAS. It seemed slow and when I checked the transfer rate it read 11MB/s. The file I was transferring was 770MB. I have the NAS connected through my Fritzbox Router which has gigabit ports through Cat5 cable. My NAS is a Readynas NV+ with two 2 Tb Samsung drives installed. Is this speed normal and if not what can I do to improve it?
Thanks
Loquacious - sphardy1Apprentice
loquacious wrote: I have the NAS connected through my Fritzbox Router which has gigabit ports through Cat5 cable.
CAT5 cabling does not support gigabit performance - you need to change your cables for CAT5E or better, else you will be restricted to the 100Mb/s ethernet speeds you are seeing - loquaciousAspirantTo be honest I am not sure if my cable is Cat5 or Cat5E how can I tell which it is?
- dbott67GuideCheck to see what's written on the cable jacket:
- loquaciousAspirantI am using the cable that came with the NAS wouldn't that be at least Cat5E ?
- loquaciousAspirantNo matter what I try I cannot get tranfer speeds better than 11MB/s. I have changed cables, even disabled options that were recommended to be disabled to improve speed. The network status on my NAS frontview page says it is "Online / 1000 Mbit / full duplex but still only getting 11Mb / second transfer speeds from my internal hard drives to the NAS.
loquacious wrote: I am using the cable that came with the NAS wouldn't that be at least Cat5E ?
While that might seem a reasonable expectation, in my experience it is a completely wrong one
