michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread for easy comparison.
You can run IO Meter by following the steps here: http://www.infrant.com/forum/viewtopic.php?t=265
Please post your hardware specs, other relevant info, and IO Meter results. Maybe this could get stickied? Or ignored if no one cares :)
Here's my info:
Stock NV
4 x Seagate ST3250823AS 250gb Hard Disk in X-RAID
All journaling disabled
Fast writes on
Intel D805 2.66ghz dual core cpu
Intel D945GNTLKR motherboard with onboard Intel Gigabit NIC
2 gigs ram
Seagate ST3250824AS 250gb Hard Disk
Windows Vista x86 RC1 (if that makes a difference)
Dell PowerConnect 2708 Gigabit switch (no jumbo frames)
Cat 6 cabling
IO Meter Write: 19.321793 MBps
IO Meter Read: 26.803979 MBps
Here's my info:
Stock NV
Fast writes on
2 gigs ram
Cat 6 cabling
- tiranorAspirantI'm wondering, is CIFS that slow, or do i have a misconfiguration ?
Tonight, i was transfering files with ftp while sabnzbd was DLing at full speed (2MB/s), the speed was 100+ MB/s. And on the other hand, i can't seen to exceed 50-60MB/s with CIFS. - glashoppahAspirantI am definitely seeing a very large difference in write speed between the cache and the disks. When I initiate a write I get 800+ Mbit/sec for about 700MB of data, and then a halt while the NAS writes to disk, then a very consistent pattern of around 100Mbit/sec for 200MB of data and then halt as the NAS writes it, repeat, until the data is all sent. If I send less than 700MB, then it is like lightning, but once the cache is full my writes are much slower.
H. - tiranorAspirantThe problem seems to lie with your HDDs :/
What models ? What does the SMART say about them ? You could also install bonnie add-on and see what you get. - glashoppahAspirantMine? I have 6x Seagate Constellation ST32000644NS drives. No problems in SMART listed. I have Bonnie installed but it was unreliable so I disabled it.
H. - glashoppahAspirantI take it back - it was the ntop addin that sucked.
Here is the Bonnie result.Version 1.96 Sequential Output Sequential Input Random
Seeks Sequential Create Random Create
Size Per Char Block Rewrite Per Char Block Num Files Create Read Delete Create Read Delete
K/sec % CPU K/sec % CPU K/sec % CPU K/sec % CPU K/sec % CPU /sec % CPU /sec % CPU /sec % CPU /sec % CPU /sec % CPU /sec % CPU /sec % CPU
JCM-NAS1 8G 381 95 15904 2 57526 13 1452 98 314401 31 576.9 12 256 12581 40 252951 99 2485 7 17598 55 325070 99 1535 4
Latency 21149us 37772ms 669ms 27128us 51434us 97051us Latency 1982ms 1439us 6919ms 359ms 23us 6661ms
H. - glashoppahAspirantUgh, that didn't format well.
H. - chirpaLuminary
Wrapping with a CODE block helps a bit.glashoppah wrote: Ugh, that didn't format well. - tiranorAspirantWell, as i see (i've formatted it with excel), your benchmark clearly shows a problem with sequential outpout. It shows 15.9MB/s, with 2% CPU load (and 37000ms latency), while mine reaches 100MB/s (and my ultra4 is crealy slower than your Pro6).
- glashoppahAspirantOdd - first of all I don't have any problems reading *from* the ReadyNAS, it seems to be able to put data on the wire just fine. And my Mac has a lot of RAM and a hardware controller and apparently a great caching strategy, so it can take whatever the NAS dishes out. I get data out of the ReadyNAS at very consistent and high rates.
It's writing *to* the ReadyNAS that is slow and choppy and clearly governed by drive performance and caching.
Regarding the issue you note - any ideas? This device is configured relatively "out-of-the-box" except for the double-redundancy config of XRAID-2. I've had more than one of these and have had 500G, 1T and 2T drives in them, all enterprise-class Seagate Constellations.
H. - janformanAspirantReadyNAS DUO v2
Intel NAS Performance Toolkit
Write: 39.2MB/s (314Mbit/s)
Read: 49.1MB/s (393Mbit/s)
NAS Performance tester 1.4 / 800MB file
Write: 47.6MB/s (380Mbit/s)
Read: 58MB/s (464Mbit/s)
