michelkenny
Sep 26, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread for easy comparison.
You can run IO Meter by following the steps here: http://www.infrant.com/forum/viewtopic.php?t=265
Please post your hardware specs, other relevant info, and IO Meter results. Maybe this could get stickied? Or ignored if no one cares :)
Here's my info:
Stock NV
4 x Seagate ST3250823AS 250gb Hard Disk in X-RAID
All journaling disabled
Fast writes on
Intel D805 2.66ghz dual core cpu
Intel D945GNTLKR motherboard with onboard Intel Gigabit NIC
2 gigs ram
Seagate ST3250824AS 250gb Hard Disk
Windows Vista x86 RC1 (if that makes a difference)
Dell PowerConnect 2708 Gigabit switch (no jumbo frames)
Cat 6 cabling
IO Meter Write: 19.321793 MBps
IO Meter Read: 26.803979 MBps
Here's my info:
Stock NV
Fast writes on
2 gigs ram
Cat 6 cabling
- guiriAspirantSince I'm too stupid to do the iometer thing, can someone here just drag and drop some files from the computer to the nas and tell me how long it takes?
I move a 2.15gb file in just about 5 mins either way which I think is very slow. This is an avi file.
Can anyone comment?
Thanks
GEorge - peteshoesAspirantWell - here are the results I got to when testing with the 1gig file that iometer produces:
1 gig file
MTU 1460
copy file to PC - 1 min 37
copy file to nas - 1min 5secs
12mb/s 22mb/s
MTU Jumbo
46 secs
1min 40 secs
30.2mb/s 13.8mb/s
MTU 1492
33 s
1min 9 secs
39mb/s 22.6mb/s
Pete - jaggy27AspirantWireless Performance:
Read: 3.26894MBps, (13.07576 IOPS)
Write: 2.220606MBps, (8.882425 IOPS)
Direct Connect:
Read: 16.317407MBos (65.269628)
Write: 20.365237MBps (81.460949 IOPs)
Router: D-Link, DL-4500
Updated to latest firmware
ReadyNAS Duo
1 Single stock 500GB drive
HP pavillion dv6000 Laptop
AMD Processor, Core 2 Duo
2GB ram
Windows 7 OS
MTU: 1492 on both Laptop and ReadyNAS Duuo
Radiator at Version 4.1.4
Disabled full data journaling
Disabled journaling
Enable fast CIFS writes
Enable USB disk writes
Can anybody help with some suggestions to better speed???? - Copernicus2AspirantAre people with Windows 7 having the same speed issues I am? Running an IO meter will max my transfer speeds at about 8 MB/s both write and read. Everything seems to be running at gigabit speeds between my computer to the nas. When I switch to XP sp3 I have no issues reaching 29 MB/s.
Is this a Windows 7 issues or what?
Readynas NV+ 4.1.6 firmware - jiawaAspirantI am getting:
Write 6.2 MBps
Read 4.1 MBps
I have a pretty good feeling that I am going to return it. - alphagammaAspirant
It seems like it here, but can't test, didn't install win xp on this pc yet. - mrgreenfurAspirantSince IOmeter doesn't work on mac, my xbench scores are below. The volume is mounted via AFP and the NAS has 512mb ram. Using a gigabit switch with jumbo frames:
Results 27.21
System Info
Xbench Version 1.3
System Version 10.5.8 (9L30)
Physical RAM 4096 MB
Model Macmini3,1
Disk Test 27.21
Sequential 16.40
Uncached Write 7.03 4.31 MB/sec [4K blocks]
Uncached Write 27.10 15.34 MB/sec [256K blocks]
Uncached Read 18.58 5.44 MB/sec [4K blocks]
Uncached Read 91.73 46.10 MB/sec [256K blocks]
Random 79.86
Uncached Write 42.93 4.54 MB/sec [4K blocks]
Uncached Write 47.13 15.09 MB/sec [256K blocks]
Uncached Read 619.35 4.39 MB/sec [4K blocks]
Uncached Read 252.37 46.83 MB/sec [256K blocks] - Copying 750 MB file over AFP from 2009 Mac Pro to ReadyNAS Pro Business:
With my Macintosh G5, the fastest I could push data to my NAS was about 57 megabytes/second -- which I was pretty pleased about. I just copied a 750 MB file to my NAS, and my Mac Pro topped out at 94 megabytes/second. That's 750 Mbps.
Drag-copied 5.16 GB file over AFP from Mac Pro to ReadyNAS in 53.39 seconds. Activity Monitor topped out at 104.4 MB/sec.
NetGear GS108 switch. Gig-E, no Jumbo frames, MTU 1500. Hardly any performance tweaking on the ReadyNAS Pro except: adding a UPS to turn off journaling, enabled disk write cache, optimize for OSX. RAIDiator 4.2.5, XRAID-2, 3 GB of RAM (4-5-5-15 DDR2). Using only a single Gig-E interface on the ReadyNAS (no teaming). 2009 Mac Pro, 8 GB of RAM, Snow Leopard. Seagate 7200.12 hard drive.
I did a fresh install of Snow Leopard (not an upgrade of Leopard) onto the Mac Pro.
My OCZ Vertex SSD should arrive soon; I'll re-test network speed then. - berkut1TutorSince I now have three generations of ReadyNAS, I thought I would post my test results. One key point is that for this system I found that disabling Jumbo Framing on all of the devices, gave the best results. I also found that setting the PC's NIC to maximize network throughput vs. CPU utilization made a significant improvement in overall performance. The cost of this operation resulted in CPU utilization increasing from 10% to 30-44% during testing.
NAS0:
ReadyNAS X6
RAIDiator 4.1.6 [1.00a147]
512 MB [2.0-2-2-6]
X-RAID, 4 disks, 86% of 1368 GB used
Jounaling Enabled, Fast CIFS writes, Fast USB writes
Static IP, 1000-BaseT, Jumbo Frames Disabled
CIFS, HTTPS, Rsync Enabled
NAS1:
ReadyNAS NV+ [X-RAID]
RAIDiator 4.1.6 [1.00a043]
1024 MB [2.5-3-3-7]
X-RAID, 4 disks, 45% of 2776 GB used
NAS2:
ReadyNAS Pro Pioneer Edition [X-RAID2]
RAIDiator 4.2.5
1024 MB [4-5-5-15 DDR2]
X-RAID2, 6 disks, 27% of 4611 GB used
CIFS, NFS, HTTPS, Rsync Enabled
PC
ASUS A8N-SLI Premium - AMD64 X2 2.4GHz
2 GB [2.0-2-2-5]
Windows XP Pro - SP3
NTFS, RAID 0+1 - 4 disks, 50% of 465 GB used
Network Switches:
SMC GS16 16 ports - 10/100/1000T w/ JF 9K Support
PC<=GS16=>NAS0:
Read Throughput: 27MBytes/sec
Write Througput: 17MBytes/sec
PC<=GS16=>NAS1:
Read Throughput: 37MBytes/sec
Write Througput: 23MBytes/sec
PC<=GS16=>NAS2:
Read Throughput: 68 MBytes/sec
Write Througput: 88 MBytes/sec
-------------------------------------------------- - corgAspirantSorry, no IO Meter results, but FTP/Samba speeds:
ReadyNAS Duo RAIDiator 4.1.6 JumboFrames on
1GB Ram
2x Hitachi Deskstar 7K1000.B (1TB) X-Raid
2x D-Link DGS-1005D Green Ethernet, 5-Port Gigabit Switch , Jumbo Frames capable
Athlon X64-2,
4GB Ram,
XP-Home SP3,
Intel PRO/1000 MT Server Adapter PCI JumboFrames 9k
FTP/Samba Write: 20.5 MB/s (4GB linux iso)
FTP/Samba Read 25.5 MB/s (4GB linux iso)
FTP/Samba/NFS on, Journaling off, fast write CIFS, streaming off.
