JerryCallahan66
Jul 09, 2014Aspirant
POWERON cron.d missing
I am having difficulty getting my ReadyNAS NV to boot with a power on schedule. I happened to note that in the System > Config Backup the backup files /etc/cron.d/ directory there is a poweroff file ...
mdgm-ntgr
Jul 09, 2014NETGEAR Employee Retired
The power on settings are stored in /etc/frontview/poweron_timer not in /etc/cron.d
Note that to auto power on the NAS must be turned off via the auto power off. It will not auto power on if you turn it off manually.
Does your NV have a LCD screen on the front?
