JerryCallahan66
Jul 09, 2014Aspirant
POWERON cron.d missing
I am having difficulty getting my ReadyNAS NV to boot with a power on schedule. I happened to note that in the System > Config Backup the backup files /etc/cron.d/ directory there is a poweroff file ...
JerryCallahan66
Thanks for your help.
I got the secret handshake on how to ssh to the nas. As you noted, the poweroff script calls the poweron_timer file you noted. That file is intact and correct. I will take your word for it that no other program calls the poweron_timer file and I need to start from a poweroff running condition. To make this work I will need to modify the times while the system has auto-started and not yet auto-started. Right? Kind of an almost catch 22 condition. I will give it a try.
No front screen on the NV model.
Model: ReadyNAS NV [X-RAID]
Serial: <REMOVED>
Firmware: RAIDiator 4.1.12 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
IPv4 address:: 192.168.1.104
Volume C: Online, X-RAID, 4 disks, 55% of 1368 GB used
Serial: <REMOVED>
