JerryCallahan66
Jul 09, 2014Aspirant
POWERON cron.d missing
I am having difficulty getting my ReadyNAS NV to boot with a power on schedule. I happened to note that in the System > Config Backup the backup files /etc/cron.d/ directory there is a poweroff file ...
chirpa
Jul 09, 2014Luminary
Might be useful:
viewtopic.php?f=18&t=67461&hilit=+power+timer
viewtopic.php?f=18&t=18885&hilit=+power+timer
viewtopic.php?f=20&t=17679&hilit=+power+timer
Power On timer only triggers if Power Off shutdown the system. If you power down yourself, the timer is not set. I don't have a Sparc system to poke around at anymore, but look at what the shutdown/poweroff scripts do. There is a line in there to add the RTC alarm, you could mimic that to trigger custom power on timers.
