stratman4300
Mar 25, 2015Aspirant
Pro 2 disappears permanently from RAIDAR after setup
Hello all! Been banging my head against the wall on this one. We've got a pro 2 that used to work with no issues. Used to run file shares off of it and iSCSI for the lab at times. At any ra...
RX
Mar 25, 2015Luminary
Try to connect your Pro2 directly to your PC. Set a static IP address of 192.168.168.x to your PC then check if it will be detected by RAIDar and if its detected, check if you will be able to access its web-GUI. Note that the default IP address of your NAS is 192.168.168.168 :D
