stratman4300
Mar 25, 2015Aspirant
Pro 2 disappears permanently from RAIDAR after setup
Hello all! Been banging my head against the wall on this one. We've got a pro 2 that used to work with no issues. Used to run file shares off of it and iSCSI for the lab at times. At any ra...
RX
Mar 25, 2015Luminary
stratman4300 wrote: Yup, I attempted the direct connection method just now. Just set my IP to 192.168.168.50 and attempted to ping 192.168.168.168 and had RAIDAR scan with no luck. Still not seeing the NAS. :(
Try this: Turn off your NAS then pull-out all drives and label it accordingly from which bay you have pull it out. Then, while your NAS still directly connected to the PC, check if it will be detected by RAIDar without drives inside it.
