stratman4300
Mar 25, 2015Aspirant
Pro 2 disappears permanently from RAIDAR after setup
Hello all! Been banging my head against the wall on this one. We've got a pro 2 that used to work with no issues. Used to run file shares off of it and iSCSI for the lab at times. At any ra...
stratman4300
Try this: Turn off your NAS then pull-out all drives and label it accordingly from which bay you have pull it out. Then, while your NAS still directly connected to the PC, check if it will be detected by RAIDar without drives inside it.
Yup! That worked! RAIDAR sees the NAS with the default IP of 192.168.168.168. :D
So what does that usually indicate then? Corrupt filesystem on one of the drives then?
Sorry if these are noobish questions. I haven't done much with ReadyNASs. I don't really know their quirks yet. :?
