stratman4300
Mar 25, 2015Aspirant
Pro 2 disappears permanently from RAIDAR after setup
Hello all! Been banging my head against the wall on this one. We've got a pro 2 that used to work with no issues. Used to run file shares off of it and iSCSI for the lab at times. At any ra...
RX
Mar 25, 2015Luminary
@stratman4300:
Here are the links for Seagate SeaTools for Windows and WD Data Lifeguard Diagnostics for Windows respectively:
http://www.seagate.com/as/en/support/do ... in-master/
http://support.wdc.com/product/download ... =612&sid=3
I suggest that you perform the Extended Test for a thorough test. :)
