stratman4300
Mar 25, 2015Aspirant
Pro 2 disappears permanently from RAIDAR after setup
Hello all! Been banging my head against the wall on this one. We've got a pro 2 that used to work with no issues. Used to run file shares off of it and iSCSI for the lab at times. At any ra...
RX
Mar 25, 2015Luminary
stratman4300 wrote: The disks are actually Hitachi, which i haven't done any digging for a tool from them yet.
Its alright to use either the Seagate SeaTools or WD Data Lifeguard Diagnostics to run an Extended Test to your Hitachi drives.
By the way, are the Hitachi drives within the compatibility list of drives for the Pro2? You could check it on this link: http://www.readynas.com/app/hcl_disk
stratman4300 wrote: Does it make sense to factory default it again so it shows in RAIDAR, then through the boot menu tell it to do a disk check?
Just a reminder, doing a factory reset will wipe out all the data stored in your existing drives.
